Fuel pressure gauge adapter
2003 FORD TAURUS
97,405 MILES • 3.0L • V6 • 2WD • AUTOMATIC
ETHER727
  • 14 POSTS
I use a Star pressure gauge with an adapter to connect to my fuel line with no problem. On the 2003 Ford Taurus, I don't see any connection for a fuel pressure gauge. There is a chrome bolt on the end of the rails? I am trying to identify the type of adapter that I can install in place of the bolt to connect my fuel gauge. Or is there a connector some were other than the fuel rails for me to check the fuel pressure?
Sincerely, Paul
Aug 4, 2019 at 8:42 AM
SCGRANTURISMO
  • 4,897 POSTS
There is a valve in the fuel rail called a schrader valve. This is the valve to screw your fuel pressure gauge into if the coupling is a female one, or it can be unscrewed and the fuel pressure gauge screwed in place there if it is a threaded male coupler. You can also get brass connectors at your local hardware store for different mating situations. Please keep us informed as to how everything turns out.
Thanks,
Alex
2CarPros
Aug 5, 2019 at 6:29 AM
