Hello, I have a question about my vehicle listed above. Car runs oddly, it feels like engine wants to shut off sometimes, sometimes it won’t respond when I step on a gas pedal for a couple of seconds. It feels like engine power is decreased and gas mileage is dropped. I replaced air filter, spark plugs, cleaned MAF sensor, without any change. There is no check engine light on, so I decided to measure fuel pressure. First, I measured with fuel pressure regulator vacuum hose connected to intake manifold. It was 36 psi, which is 2 psi higher than normal (30-34psi). Then, I measured with fuel pressure regulator vacuum hose disconnected, and it was 46psi, normal(41-46psi). So overall fuel pressure is little bit higher than normal. Another thing I noticed is that when I shut off the engine fuel pressure drops rapidly to 5 psi, and I know it is not good. There are no obvious fuel leaks anywhere. So, what can it be? Can fuel pressure regulator be bad?
Sep 29, 2019 at 10:21 AM
