fuel pressure code P2540?
2008 MERCEDES BENZ E63 AMG
170,000 MILES • V8 • 2WD • AUTOMATIC
BHAMDOC1
  • 100 POSTS
It had few codes that could be related or not, I deleted all to see what stay, you can drive it with check engine light off till you start it again. The only code that came back is P2540:LOW PRESSURE FUEL SYSTEM SENSOR CIRCUIT RANGE/PERFORMANCE
Jan 9, 2026 at 9:49 AM
BHAMDOC1
  • 100 POSTS
Here us a video if that helps
Jan 9, 2026 at 10:48 AM
Yep, 9 times out of 10 it will be the sensor which is located at the tank on top of the low pressure fuel pump. Other possibilities are the fuel check valve is stuck open, the low pressure fuel pump is bad, or you have water in the tank (rare). Here is the location of the low pressure sensor so you can swap it out and then clear the codes. Luckily there is a trap door for the fuel pump. Check out the images (below). Please let us know what happens.
Jan 9, 2026 at 12:07 PM
BHAMDOC1
  • 100 POSTS
do you know the part number if it's not too much trouble plz
Jan 9, 2026 at 12:32 PM
Sure here is the part number for the low pressure fuel pump pressure sensor.
Bosch (1561530028) Fuel Pressure Sensor
Clear the code once completed, Ken
Jan 10, 2026 at 9:09 AM
BHAMDOC1
  • 100 POSTS
Seems like this one maybe at the engine side. I thought we were talking about the one on too of fuel tank? Cause this one has bolts and in some sites says on fuel rail
Jan 10, 2026 at 9:42 AM
Hmm, good call that one does not look right. Let try this one instead.
OEM Mercedes part 1635422818
Let me know, Ken
Jan 11, 2026 at 9:08 AM
BHAMDOC1
  • 100 POSTS
Changed it, which was under the rear seats. Got a code p0193 without check engine being on
Jan 15, 2026 at 7:46 AM
NICE!! so we got the one problem fixed. Please start a new thread for the p0193 code. Which will involve the high pressure pump. Are you sure this car has the correct fuel, and the fuel is not contaminated?
Jan 15, 2026 at 11:17 AM
BHAMDOC1
  • 100 POSTS
Changed the fuel rail sensor because i kept getting p02540. As soon as i delete it and restarts it comes right back. Strange. So this sensor and the one on the left side of the rear seat which is the sender unit that also has a sensor, i replaced both with Bosch quality, i hear the right side pump strong every time i tirn the ignition on so not sure what else is there.
Feb 5, 2026 at 4:17 PM
BHAMDOC1
  • 100 POSTS
What do I do if I don't know if the correct fuel is in it? it has 1/2 tank, should I add a Techron cleaner?
Feb 5, 2026 at 5:17 PM
Yep, that can help, especially if the car has been sitting.
Feb 6, 2026 at 7:45 AM
BHAMDOC1
  • 100 POSTS
any specific brand you tried and can recommend?
Feb 6, 2026 at 8:35 AM
This is what I would use
https://amzn.to/4raz0ym
Let me know what happens.
Feb 7, 2026 at 8:56 AM
