fuel pressure high. change regulator, it starts but shuts off. bleed pressure to about fifty starts and runs if keep bleeding pressure.
Feb 15, 2017 at 9:30 AM
STEVE W.
CERTIFIED EXPERT
Sounds like the regulator is faulty or the return line back to the tank is blocked or both. Should be around 45-48 psi. 90 will work the pump to death.
Feb 15, 2017 at 10:10 AM
JMOCK
MEMBER
have change pressure regulator remove return line no gas coming out of return line.
Feb 15, 2017 at 10:58 AM
JMOCK
MEMBER
figured out fuel rail plug with dirt.
Feb 15, 2017 at 12:47 PM
STEVE W.
CERTIFIED EXPERT
That will do it. but, I will bet it is not dirt as much as fine rust and rubber from the fuel tank and lines. I would plan on replacing or cleaning and sealing the gas tank, then flushing the lines (replace any rubber lines) and you should be okay. What you are seeing is the effect of ethanol on rubber and steel.
