After the car has not been running for a few hours the engine will stumble, sputter at startup for a few seconds and then run smoothly. But if I turn the switch and leave it on for a few seconds, then crank the engine to start, it will run fine. No stumble. I had someone turn the switch to on only while I listened over the right rear seat and the pump motor will run for a few seconds and shut off. I immediately had them turn the switch off and back on and the pump ran again, and it shut off in two or three seconds. Had them turn the switch on third time, same thing. Pump ran and shut off by itself. Is the fuel line losing pressure that quick? I have not installed a fuel pressure gauge on the system yet. There are three parts stores in town. I hope one of them has a gauge I can rent. And I checked one spark plug, no deposits but was black. So, it is running rich. Would an injector leak fuel into a cylinder. I am just looking for answers to questions I have in my head. I like to do my own work, but I need help on this.
Jan 6, 2025 at 6:07 PM
