Long crank time! Did fuel pressure test! With key on holds at 55 psi. Van running holds at 55 psi without any needle movement. Did leak down test on pump and injectors. The injectors holding with no needle movement. Pump side drops to 45 psi after fifteen minutes. There is no pressure regulator on this van. With my understanding it is built into the pump. This test is telling me that the check valve in the pump is getting weak. The question is, can I install an inline check valve to hold the pressure at the injectors?
Mar 1, 2018 at 8:20 AM
