If you turn the switch on and leave it on for a few seconds you can hear the fuel pump run then shut off, if you do this a few times the car will start and run for a minute or so then stop. changed the mass air flow sensor no change, changes crankshaft sensor no change. if you spray starting fluid into the air intake lightly continuously it will stay running, can't locate fuel pressure regulator/sensor, checked under back seat on fuel tank and followed the fuel line from the injector rail to tank and nothing. Help, please and thank you.
Jul 31, 2023 at 1:28 PM
