At first when I would drive it i could barely get it up to fifty five mph and when I would go up an incline it would loose all power and barely go up it. I changed fuel pump and fuel pump housing because the fuel gauge was not reading accurately. It seem to help it now i can get it up to sixty five to seventy mph with no problems, but it still looses power on inclines and fuel gauge is still not accurate. I did a pressure test and with key on engine off it is at 8 psi from what i read its suppose to be 35-40 psi and with engine idling its at 41 psi which is within normal. I do not want to spend $80.00 on a new regulator if it is not the problem.
Jan 21, 2018 at 3:20 AM
