Fuel pressure
1994 FORD EXPLORER
330,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
JON SPRADLIN
  • 5 POSTS
At first when I would drive it i could barely get it up to fifty five mph and when I would go up an incline it would loose all power and barely go up it. I changed fuel pump and fuel pump housing because the fuel gauge was not reading accurately. It seem to help it now i can get it up to sixty five to seventy mph with no problems, but it still looses power on inclines and fuel gauge is still not accurate. I did a pressure test and with key on engine off it is at 8 psi from what i read its suppose to be 35-40 psi and with engine idling its at 41 psi which is within normal. I do not want to spend $80.00 on a new regulator if it is not the problem.
Jan 21, 2018 at 3:20 AM
Good morning.
it is a good possibility that your catalytic converters are clogged. I would have the back pressure checked. it is a test where you remove an O2 sensor and insert a gauge and run the engine. if there is back pressure above one to two lbs, they are clogged.
Jan 21, 2018 at 4:32 AM
JON SPRADLIN
  • 5 POSTS
It does not have a catalytic converter.
Jan 21, 2018 at 9:51 AM
okay, then I would start with a compression test. it will give us an idea to see if the timing chain has slacked off.
Jan 21, 2018 at 9:54 AM
JON SPRADLIN
  • 5 POSTS
Okay, I will try that.
Jan 21, 2018 at 9:55 AM
Let us know the results.
Jan 21, 2018 at 9:57 AM
JON SPRADLIN
  • 5 POSTS
I also forgot to add that when I first start it up after it has sat for a little bit i have to let it run for about ten to fifteen minutes to warm up or it will not move. it will spit and sputter.
Jan 21, 2018 at 10:10 AM
okay, let's start with the basics.
Jan 21, 2018 at 10:11 AM
JON SPRADLIN
  • 5 POSTS
Did pressure test the gauge read 165 on all six cylinders.
Jan 21, 2018 at 11:24 AM
okay, that is good.
you have fuel pressure and compression.
check the spark from the coil to see if it is a good snap.
also, injectors are next stop to see if they are working.
Jan 21, 2018 at 11:31 AM
