I am going to conduct a fuel press check, where is the Inertia switch location?
1994 FORD RANGER
109,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
GOGOJUICE6
  • 76 POSTS
I'm going to do a fuel press check on my ranger. The manual reads that in order for the pressure to be relieved, I have to unplug the fuel pump switch. According to the manual, the switch is "directly behind the glove compartment". Can't find it. Do you guys have an idea of the location and what does it look like? Thanks a lot for your help. It is greatly appreciated.
Al
Aug 27, 2022 at 9:19 AM
The inertia or fuel pump cut off switch is located on the passenger's side under the carpet. check out the image below to show you where it is. This guide can help you with the fuel pressure test:
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Aug 27, 2022 at 11:40 AM
GOGOJUICE6
  • 76 POSTS
HI, Ken. First of all, thanks for such a fast response, outstanding. Secondly, I noticed that the diagram you sent is for a v-6 3.0L. Mine is a 4 cylinder 2.3L. Are the switches mounted in the same place regardless of engine size?
Again, thanks for the fast response. You guys are awesome!
Al
Aug 27, 2022 at 2:55 PM
Oh yeah, it is in the same place, pull the carpet back and you should find it. We are here to help anytime. :)
Aug 29, 2022 at 12:25 PM
