my car it bucks then stalls sometimes?
2012 HYUNDAI ACCENT
101,000 MILES
JACQUELINE WALLEY
when i start my car, it bucks then stalls sometimes i put it back in park it stops bucking then sometimes when i drive it bucks a little like it wants to stall has power though.
Feb 4, 2024 at 9:14 AM
This can happen when you have a vacuum leak. But we should run the codes to see if any codes are stored.
This guide can help:.
Can I ask if you changed the spark plugs? If not, I would start there as well, also I would service the throttle body.
These guides can help:
and use this guide when the engine is cold only.
Here is information on how to do the work on your car.
Gap .................... 0.9 - 1.0 mm (0.035 - 0.039 in)
I would replace the ignition coils as well; they go out along with the spark plugs. Check out the images (below). Please upload pictures or videos in your response to the problem so we can see what's going on.
Feb 4, 2024 at 12:16 PM
JACQUELINE WALLEY
car misfiring said to change spark plugs and ignition coils did so, and same problem.
Feb 4, 2024 at 12:17 PM (Merged)
BORIS K
  • 836 POSTS
Have you had a CAN-scan done on your vehicle to determine which cylinders are misfiring?
How to do a scan:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
This scan will reveal which cylinders are affected by the misfire.
A good video on how to diagnose a misfire on your vehicle:
https://youtu.be/icWZYTKLets
A good guide:
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
Hope this helps.
Cheers, Boris
