These are the instructions and routing of the fuel lines on the Chassis going back to the fuel tank, the 2nd diagram with the transfer case will not apply for your vehicle being 2WD, To relieve any fuel pressure before disconnecting lines or adapting a fuel pressure gauge to the Fuel rail, you can pull the fuel pump relay and crank the engine over, it may start for a few seconds, but will then stall out due to fuel pressure dropping off. The fuel line diagrams look the same for the Flex Fuel and conventional system. If you need any further info just let us know.
Jul 15, 2025 at 10:30 AM
