fuel lines "rusting out"
1998 BUICK PARK AVENUE
190,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
DCKELLEY
  • 125 POSTS
i had an oil change today and the pit guy said my fuel lines were rusting out. calling for more information tomorrow. my question is, if my lines are good except for a couple places can i do a repair? any certain type of line? is there a fuel injector type of nylon fuel line for repairs? as usual i'm on a fixed income don't want to change all the lines if not necessary. Don
Feb 13, 2019 at 7:35 PM
DCKELLEY
  • 125 POSTS
How critical of a situation is this? one parts store guy i talked to said just wait until they start leaking. Hmm
Feb 13, 2019 at 7:40 PM
STEVE W.
  • 15,113 POSTS
Yes, it is possible to repair the lines with sections, the tubing used is the same that is used for brake lines. Without seeing them it would be hard to say if it's critical. I wouldn't wait until they leak as that could get dangerous depending on the location of the rust and where the line fails. If it failed next to the exhaust and sprayed onto it that wouldn't be good.
When I do lines I replace the entire line with new, simply because the fittings and time it takes to make the flares and cut and prep the old lines so they will seal is usually more than just running a new line.
Being steel lines they can have a lot of rust and still be okay. If you could get pictures of the bad spots it would make it easier. Another option if the lines are just surface rusted would be to scrub the loose rust off with a scotch brite pad and paint the lines with cold galvanize paint, until you had the funds/time to do a replacement.
Feb 14, 2019 at 2:34 AM
DCKELLEY
  • 125 POSTS
i haven't had a chance to talk to the guy. i hate to have to have a mechanic put it on a hoist just to check it out.(cold and snow) if the guy had said anything but rusting out i won't be worried. maybe it is just some pitting. I've heard of this spray on oil product that works great to stop rust. thanks for your input. like you said who knows until you see it?
Feb 14, 2019 at 6:30 PM
STEVE W.
  • 15,113 POSTS
That's the catch, until you see it you don't know how bad it really is or isn't. Depending on where you live it could be minor. Where I am in NY those lines would be replaced already, probably with the rest of the car due to the salt eating it.
Fluid film or Krown would help slow the rust down. Not sure if they would do it but you could visit the same oil change place and ask them to either show you or take pictures of the rusted lines, just to get an idea of what they are like. Or call a couple shops and ask how much it would be to put it in the air just to look at it. I used to do things like that all the time for people who were worried. Then give them an estimate for repair and replace.
Feb 14, 2019 at 7:44 PM
DCKELLEY
  • 125 POSTS
Minnesota. 190,000 and unbelievably it's pretty clean underneath for these salty roads.
Feb 14, 2019 at 10:00 PM
STEVE W.
  • 15,113 POSTS
I wish a NY car would last that long. We hold the records for salt use on the roads over every US state and Canadian provinces as well. Plus they use beet juice/brine nix, and various other brine mixes. May as well drive the vehicle off a dock into the ocean, it would last longer.
Feb 15, 2019 at 6:52 AM
DCKELLEY
  • 125 POSTS
well, i got back to the place and they took some pictures for me. it looks to be leaking by the plastic connector. the line going back to the tank looks quite rusted too. it looks like that is the original filter. i may have someone find good steel and splice the rear (with new connector) maybe with a new filter the front will be okay? might just be a shot o-ring.
pretty isn't it? advice would be appreciated. Don
Feb 16, 2019 at 10:23 AM
DCKELLEY
  • 125 POSTS
in photo two it looks like the fuel may also be leaking at that quick release. where does that run and can that release be changed?
Feb 16, 2019 at 3:54 PM
DCKELLEY
  • 125 POSTS
the one "behind" the filter.
Feb 16, 2019 at 3:57 PM
STEVE W.
  • 15,113 POSTS
That is a wee bit rusty. I would change the steel line and filter. The quick connect might be seeping due to the rust on the line. They can be changed but you can also replace just the inner o-ring if they leak. What you have there are three lines. One is the fuel line with full pressure, it is the one with the filter. Then there is a fuel return line, that is the one tighter to the frame. Plus there is the EVAP line, that one carries fuel vapor from the tank. That one will turn on the CEL if it leaks.
Have seen them a lot worse though.
Feb 16, 2019 at 4:50 PM
DCKELLEY
  • 125 POSTS
where does the pressurized fuel line go to?
Feb 16, 2019 at 4:54 PM
DCKELLEY
  • 125 POSTS
does the back side of the fuel filter, the steel line go directly to the tank? if so i'm going to find a good non-rusted place to splice using high pressure fuel hose.
advice is always welcome. thanks for you help. Don
STEVE W.
  • 15,113 POSTS
The line goes from the filter back to the in tank pump. There is a quick connect at that end as well. If you want to replace it and use a line that is easier to deal with than the OEM steel you could opt for NiCopp alloy line. It is a nickle copper alloy. It bends and flares like copper tubing but can be used for fuel and brake lines. It's more money but it is really easy to work with and it doesn't rust. I've replaced a lot of brake, fuel and other lines with it. It also has the ability to be polished so it looks like gold!
Feb 16, 2019 at 5:45 PM
DCKELLEY
  • 125 POSTS
that stuff sounds awesome. truth is I'm on a fixed income. i want to do this as cheaply as i can and still be safe.
Feb 16, 2019 at 6:01 PM
DCKELLEY
  • 125 POSTS
The size of the fuel lines these old Buick's is 3/8 right?
Feb 16, 2019 at 6:02 PM
DCKELLEY
  • 125 POSTS
Steve! is that line attached to the fuel pump!? i can access that through the port in the back! please tell me i can feed that piece up there!
Feb 16, 2019 at 9:53 PM
DCKELLEY
  • 125 POSTS
that's what you meant by they make that part ready made. any idea part number?
Feb 16, 2019 at 9:59 PM
DCKELLEY
  • 125 POSTS
i can be really thick sometimes.
Feb 16, 2019 at 10:00 PM
DCKELLEY
  • 125 POSTS
i have the fitting on top all i need is the tube. i can't find the part online..
Feb 16, 2019 at 10:25 PM
STEVE W.
  • 15,113 POSTS
The connectors they used are pushed into the tubing with barbs to seal them. There will be a short rubber section that has the fitting for the steel to attach.
FINELINE makes a full replacement line set for your car FL251B Runs about $140.00 Gives you all three of the lines, new filter and is a plug and play item. The lines are all pre bent and come as two pieces so they fit without a big fight.
Rock Auto carries them.
Feb 17, 2019 at 8:03 AM
DCKELLEY
  • 125 POSTS
Thanks.
Feb 17, 2019 at 9:22 AM
STEVE W.
  • 15,113 POSTS
You are welcome. I gave you that option as it is probably easier and faster and probably cheaper overall when you look at the parts you get as rusted lines have a bad habit of leaking in other places as soon as you start moving other parts. Keep us in the loop as to what you decide. Thank you for using 2CarPros.
Feb 18, 2019 at 4:39 PM
DCKELLEY
  • 125 POSTS
Thanks again. you gave great advice and information. i love this site!
Feb 18, 2019 at 5:10 PM
STEVE W is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Feb 21, 2019 at 10:53 AM
