You need the special adapter that goes between the supply line and the fuel rail so the gauge can tap into the line, it will be in most pressure test kits. This guide can help
Do not try cutting the line and tapping in, it will leak and probably fail. If the pressure test kit you have does not have it check the parts stores for them, they are a common fitting. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Apr 13, 2018 at 5:15 PM
