I am unsure of the fuel line size and so even though I have found an identical part I am unable to order because I don't know the correct size
Oct 31, 2019 at 8:26 AM
CERTIFIED EXPERT
I believe it is 5/16" line. Where exactly is the location you need to repair? I just want to make sure it isn't a vapor line because that is 3/8". Take a look at the attached pic and let me know if that is the type of quick connect you are dealing with. The picture basically shows how to disconnect the fitting.
