Welcome back:
If it stops getting gas, it would stall. Based on that, I believe you mean there is no throttle response. This vehicle has a throttle cable and a cable so it wouldn't be a sensor issue causing it. I have attached a picture of the throttle cable and mount for you. Make sure the cable and all retainers are tight, not slipping, and nothing is bent allowing the throttle to drop off even though you are not releasing the throttle.
If I misunderstood what you are asking, let me know. Also, let me know what you find or if you have other questions.
Nov 27, 2018 at 5:09 PM
