I have my second fuel line leak in 2 weeks. Shop mechanic repaired the first leak. He tells me if I’m handy I can repair this leak. And he tells me the return line needs to be replaced. I found this new leak is above a frame part where the lines turn from frame rail run to head towards back of engine. I can’t see the lines at that point but I have a lot of gas dripping from the frame and the car is a bit hard to start now. I plan to replace the supply line between the fuel filter and the engine. Right now the car has steal line up to about 8-10 inch from fuel rail quick disconnect. That 8-10 inch is some type of plastic line. Looks like it is somehow pressed over the quick disconnect and over the steal line. I assume this is factory. I have a few questions. What size nylon line should I order ( 5/16 I d ? With caliper the o d is 3/8). Can I cut that plastic hose off the quick disconnect and push it into 5/16 nylon and put a hose clamp onto it?
On the other end. At the fuel filter right now I have the old steal line going into a short piece of rubber hose. And it is held by two hose clamps. Then the short hose goes to the fuel filter and is held by hose clamp. Can I push the 5/16 nylon inside the hose like the steal line is now and reuse the hose clamp?
If I can’t use the old quick connect can I get a quick connect that I can put onto nylon line? Also, if can’t put nylon hose into rubber hose at fuel filter how do I connect nylon hose to fuel filter?
If you have part numbers or exact info on the nylon hose I need and connectors that would be great.
Thanks
Dean
Thanks
Dean
Aug 10, 2019 at 8:26 PM
