Fuel issues
2004 FORD EXPEDITION
140,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
COURTNEI
Car cranks but won't start. It sounds like its trying to start but it doesn't.
I've changed the fuel pump, fuel filter, inertia switch, and fuse box
Mar 19, 2016 at 7:57 PM
COURTNEI
BTW: The fuel switch that I just purchased (directly from ford 2 days) will not stay down could this be an issue? And is there anyway to bypass it?
Mar 19, 2016 at 9:54 PM
Hey Courtnei,
Yes the inertia switch should stay down, you may have pinched some wires when doing the pump which is common when replacing the pump. Try disconnecting the switch and use a jumper wire to bypass it to be sure, the fuse will blow if you shorted out a wire.
Please get back to me
Mar 19, 2016 at 10:05 PM
