Fuel injectors not sealing properly
2005 SCION XB
200,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
KLLER256E5
I replaced the fuel injectors on my car and I can't seem to get them to seal right. is there a torque spec or something that I'm not doing right that is it keeping leaking gas out the top? I've tried a different gaskets on it, I'm just not quite sure what to do with it anymore.
Feb 8, 2019 at 10:59 AM
SCGRANTURISMO
  • 4,897 POSTS
Fuel injectors should have nitrile rubber o-rings on top and bottom of the injector. When installing the injectors into the fuel rail and the intake manifold or head, wherever the bottom gets pushed into, you should lightly grease the o-rings and make sure that they go into where they are going snugly and solidly. Ensure they are pushed into their sockets all the way. Tighten the fuel rail fasteners to specs and you should have no problem with them leaking. I hope this helps.
Thanks,
Alex
2CarPros
Feb 8, 2019 at 11:15 AM
Here is a guide to help walk you through the steps of changing the fuel injector and instructions and diagrams below so you can see how to do the job on your car:
https://www.2carpros.com/articles/how-to-replace-a-fuel-injector
Feb 8, 2019 at 12:16 PM
KLLER256E5
Thank you very much.
Feb 8, 2019 at 12:19 PM
Let me know how it goes :)
Feb 8, 2019 at 12:58 PM
KLLER256E5
It was the top of the number two injector the o-ring was pinched. thanks for the help guys I really appreciate it.
Feb 8, 2019 at 6:40 PM
Nice work, we are here to help, please use 2CarPros anytime.
Feb 9, 2019 at 6:09 PM
ALFREDM8702
  • 109 POSTS
Ok my xb needs injectors and i have some new injectors for at tc will the fit?
Feb 9, 2019 at 6:09 PM (Merged)
We only recommend direct fit parts. Chances are there is a difference between the ones in the car and the new ones you have.
ALFREDM8702
  • 109 POSTS
I check online and they say the tc has more ccs will that matter?
yes, the computer in the vehicle won't compensate for the difference.
ALFREDM8702
  • 109 POSTS
OK thank u
Glad to help
JIM4SAIL
First let me confess, I made a mistake. I loosened the fuel injection rail by mistake, and fuel began to spray all over. I immediately tightened it, but I can't get it to seal. Every time I start the car it sprays a lot of gas in just seconds. Seems to be worse on the injector at the 1st cylinder, but might be spraying from others. Help!!!
You need to check every injectors O-ring/seals-might not be seated
JIM4SAIL
Thanks for the reply. I'll pull the rail tomorrow when I have more light. I'll let you know how it goes. Can the o-rings be reused if they're not cut or do they need to be replaced if the seating of the o-ring is lost?
Feb 9, 2019 at 6:10 PM (Merged)
Best you replace it all-
