Will not stay running
1991 OLDSMOBILE CUTLASS
121,000 MILES • 3.3L • V6
LUCKYUNICORN
Car cranks will run five minutes and shuts off. Fuel injectors?
Dec 29, 2018 at 7:32 PM
First, check to determine if there are any diagnostic trouble codes stored. They will help diagnose the issue. Here is a link that shows how it is done. All you need is a paper clip on this system.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Next, if it runs and then shuts off, either you are losing spark or fuel pressure. It isn't uncommon for a bad crankshaft sensor to do what you described. Take a look through this link::
Also, here are links that show how to check fuel pressure and for ignition spark. You should do this when the engine dies and doesn't restart.
Dec 29, 2018 at 7:48 PM
