Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
F-150
Fuel System
Fuel Injector
Replace/Remove
fuel injector replacement instructions?
2008 FORD F-150
123,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
MISCARLETT_1
MEMBER
1 POST
FOLLOW
how to replace the fuel injectors?
Feb 11, 2016 at 7:48 AM
CERTIFIED EXPERT
Here are a couple guides that will help with this. First is how to test the injectors. This will show the proper way to test the injectors in the event you need to do that, plus a guide on how to replace them.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
https://www.2carpros.com/articles/how-to-replace-a-fuel-injector
Below you will find the process on how to replace the injectors from the manual. Let us know if you have questions. Thanks
Feb 5, 2021 at 4:15 PM
