Hello, we can get a wiring diagram for you, make sure to check all the fuel injector connectors for any broken or loose pins inside the connectors, pin fitment issues can cause an open circuit effect if not making proper contact. I'll post further information in a couple minutes.
Something you can check if you have a multimeter is, with the key off, unplug the fuel injectors and check the resistance on the two pins of the injector itself, if its and open circuit inside the fuel injector you won't get any reading, the meter will read OL, most fuel injectors are 12-14 Ohms of resistance for standard port fuel injection.
Jan 1, 2025 at 11:16 AM
