Fuel injector codes p0201, p0203, and p0205?
2008 CHEVROLET MALIBU
139,482 MILES • 3.6L • V6 • 2WD • AUTOMATIC
MVANN74
  • 65 POSTS
Hi. I have the car listed above LTZ model.
I have DTC codes p0201, p0203, and p0205 circuit open on those injectors. Also causing misfires in those cylinders. Funny thing is in under hood power distribution box fuse # 43 was blown. Inserted new fuse blown again. What could be causing the fuse to be blown and do I need to pull the intake manifold and trace the pink and black wires in harness to fuse box to find issue?
Feb 27, 2024 at 9:30 PM
BORIS K
  • 836 POSTS
Apart from injectors 1, 3, 5 fuse F43 also supplies ignition coils 1, 3, 5
Suggest to first disconnect the ignition coils and see if the fuse blows again.
The pink/black wire supplies each ignition coil on pin D.
Cheers, Boris
Feb 28, 2024 at 6:23 AM
MVANN74
  • 65 POSTS
Thank you for responding. Unplugged coils, fuse still blows.
Feb 28, 2024 at 1:51 PM
Now unplug the injectors 1, 3, 5 and replace the fuse, then plug the injector one at a time until the fuse blows, this will be the bad injector. Here is how to change the bad fuel injector out. Check out the images (below). Please let us know what happens.
Feb 29, 2024 at 3:58 PM
MVANN74
  • 65 POSTS
Thank you for responding. Update, I ended up tracing all the pk/blk wires from injectors to fuse box. Heavily wrapped in loom and tape was a bundle of pk/blk wires. 4 of them were not quite melted but stuck together. I separated them, reinstalled fuse 33, turned on ignition and fuse didn't pop. It took about 10 hours over a 2day period, but the car runs fine at this time. Again, thank you for the help.
Mar 1, 2024 at 2:43 AM
BORIS K
  • 836 POSTS
Thank you for the positive feedback.
Cheers, Boris
Mar 4, 2024 at 2:22 AM
anything?
May 11, 2024 at 11:52 AM
