My 2002 Avalon has codes PO302 and PO420. The check engine light was flashing. The engine was shutting off. The spark plugs were fouled and replace along with 3 ignition coils. The cat was replaced. The oil had gas in it. The oil and filter was changed.
Where did the gas in the oil come from? If the fuel injectors are leaking, can they be sufficiently cleaned with a fuel injection induction service by connecting to the fuel service port and running a can of fuel cleaner directly through the injectors? Where is the service port located? Would this has a good chance of solving the problem of the gas leak?
What do you advise?
Thank you greatly!
Mark
What do you advise?
Thank you greatly!
Mark
Jun 18, 2019 at 9:27 AM
