Fuel injection
1997 CHEVROLET LUMINA
240,000 MILES • 1.3L • 6 CYL • 2WD • AUTOMATIC
MICHAEL LECONA III
  • 18 POSTS
I got a leak on my fuel rail, but I changed my o-rings and bad injection.
Jan 20, 2020 at 12:24 AM
Good morning,
I would remove the fuel rail completely and change the o-rings. The o-rings that need to be replaced are where the injectors meet the rail, not at the intake manifold. Fuel will not leak from there.
I attached pictures and the one where I circled the o-rings is the ones you need to replace.
Jan 20, 2020 at 4:31 AM
MICHAEL LECONA III
  • 18 POSTS
I did that. I got all new ones and they are squirting out everywhere all over the bottom part of the manifold.
Jan 20, 2020 at 2:57 PM
MICHAEL LECONA III
  • 18 POSTS
But yeah, it leaks from the top where you circle it.
Jan 20, 2020 at 2:59 PM
Okay, that is what I thought.
You need to remove the fuel rail from the car and do this on a bench. You remove the clip that is shown in the picture and the injector will come out.
When installing the new o-ring, use Vaseline to lubricate the o-ring so it does not get damaged when you push it up and in. Then reinstall the clip to hold it.
Jan 20, 2020 at 3:16 PM
MICHAEL LECONA III
  • 18 POSTS
Do you think the clips are damage that's why it's leaking?
Jan 20, 2020 at 3:31 PM
No, I think you may have damaged the o-rings if you did not lube them and make sure they were seated.
Jan 20, 2020 at 3:43 PM
MICHAEL LECONA III
  • 18 POSTS
Okay yup. because I didn't lube them but there not cracked or broken.
Jan 20, 2020 at 3:47 PM
Do you have it apart right now?
Jan 20, 2020 at 3:51 PM
MICHAEL LECONA III
  • 18 POSTS
Yes, but I haven't unbolted the fuel rail and taken off the injectors.
Jan 20, 2020 at 3:53 PM
MICHAEL LECONA III
  • 18 POSTS
Because there's nothing much more I can do everything is in tacked.
Jan 20, 2020 at 3:54 PM
Okay, so you do not have it apart. Remove the rail and get a new set of o rings and let me know what you see.
If you can, upload some pictures of what you see.
Jan 20, 2020 at 3:56 PM
MICHAEL LECONA III
  • 18 POSTS
Okay, will do.
Jan 20, 2020 at 3:57 PM
Thank you.
Jan 20, 2020 at 4:31 PM
MICHAEL LECONA III
  • 18 POSTS
Okay, same thing happened except I didn't even make it out to the drive way.
Jan 20, 2020 at 8:05 PM
Pictures as I asked for please.
Jan 20, 2020 at 11:09 PM
MICHAEL LECONA III
  • 18 POSTS
And I had to change my fuel rail. the guy that was working on it damaged one of the inserts where the fuel injector goes was pulling out the o-ring.
Jan 22, 2020 at 12:28 PM
Okay, did that resolve the issue?
Jan 22, 2020 at 12:45 PM
Did you respond? I got an email but nothing came through.
Jan 22, 2020 at 12:50 PM
MICHAEL LECONA III
  • 18 POSTS
Yes it stopped leaking but my engine light came back on. I forgot to plug in my temperature gauge and I plugged it in and it turned off and now a couple miles after that it came on again.
Jan 22, 2020 at 12:51 PM
MICHAEL LECONA III
  • 18 POSTS
And I'm not sure what this is if it needs to be connected or not.
Jan 22, 2020 at 12:53 PM
Okay, what is the code that was set?
MICHAEL LECONA III
  • 18 POSTS
I have to get it checked on my way to check it out now. I'll let you know.
Jan 22, 2020 at 12:54 PM
No problem.
Keep me updated.
Jan 22, 2020 at 1:08 PM
