It doesnt happen every time you start the car, but a couple times a week when you start the car , the fuel gauge, temp gauge and ac compressor does not power up. Checked all fuses and all are good. One particular fuse, a 15 amp, when pulled turns on all instrument cluster light indications and when re-installed, turns all light indicators off except for security indicator and the gauges and compressor start working again. The security indicator resets when the ignition switch is turned off then back on. This morning it failed again. I pulled the fuse and immediately re-installed it and everything started working again. Do i have a bad relay? Thanks for your help.
Jul 3, 2013 at 6:15 AM
