Fuel gauge reading as full after driving
2005 HYUNDAI ELANTRA
150,000 MILES • 2WD • MANUAL
JDUB919
I filled up my car the other day and have driven about sixty miles (100 KM). The fuel gauge is still reading at full though. I am just wondering if there are any easy fixes that you can think it might be.
Thanks for your help!
Feb 14, 2017 at 4:30 PM
CARADIODOC
  • 34,306 POSTS
What is "normal" for your car? On mine, the fuel gauge stays on full for about the first 150 miles, then drops very quickly during the next 150 miles. This is typical for this model and there is no fix for it. It is even worse if I stand there and pack more and more gas into it. I can get 22 gallons into the 18-gallon tank. There is always a large pocket of air in the top of the tank to create a crush zone in the event of an impact. Some of that air will work its way out and allow you to stuff more and more gas in, if you are willing to take the time. The gauge will continue to read "full" until all that extra gas is used up.
Even when you do not pack the tank over-full, it is totally acceptable for the gauge to not start dropping right away. The exception would be if the float for the level sensor is hanging up on something. There are two clues to look for. The first is the problem started to occur shortly after some repair was done, such as replacing the in-tank fuel pump. It is not uncommon for the float to get caught during reassembly. The second clue is if the float is getting stuck, when it does finally become unstuck, the gauge will instantly drop from "full" to the correct reading. If you see the gauge at "full" one minute, and a minute later it's at "half", the float was sticking. If the gauge reading drops at a steady rate, its working correctly, even though it might take a few miles before it starts dropping.
Feb 14, 2017 at 5:46 PM
STEVE W.
  • 15,113 POSTS
If it is a sticking float you might get it to free up if you rock the car back and forth like you were trying to tip it over. Or you can give the tank a couple smacks with your hand. Then see if it moved. Next will be to just drive it and see if it drops. Going by the book mileage numbers and saying you have run sixty miles that is about two gallons of gas in a 14.5 gallon tank.
Now if you drive another sixty miles and it does not drop, then I would suspect either a bad sending unit or possibly a bad gauge.
This will give you an idea of the repair process.
https://www.youtube.com/watch?v=rSrOkNcmoUg
Feb 14, 2017 at 7:52 PM
