fuel gauge and left side of tach won't light up with rest of interior lights
2002 PONTIAC GRAND PRIX
155,503 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
2002GTP40THANNIVERSARY
i just bought the car and found out that some of the bulbs were burnt out in the dash so i went about replacing them, everything is working now except my fuel and tach backlighting. i took the bulb out (farthest to the left illumination bulb) and replaced it, even bent the bulb contacts in the socket so as to make for a good connection with the bulb, and even bent the ears for the socket down so they can get a good contact on the back of the cluster. i even tried switching sockets with another in the system so i know the socket isn't bad but I'm running out of ideas, the only thing i haven't tried is to just have the cluster rebuilt but i don't think that its worth 40 buck just to fix a light. especially since everything else in the cluster works perfectly.
Jul 26, 2014 at 10:14 AM
HMAC300
  • 48,601 POSTS
it's probably either the cluster or a body module problem and I dont'think it 's the module.
Jul 26, 2014 at 10:32 AM
i think i may have found my solution i just hardwired the sockets together with some spare wire i had lying around the house. I've just tied them altogether to see if it would work and it did. just need to make it permanent. i will be soldering the sockets and wires later to make it permanent.
Aug 4, 2014 at 3:29 PM
