Yes, it is a common problem. The sending unit's get damaged by the fuel additives. What is the gauge doing? It is possible it's the sender, the gauge or the wiring, the symptoms might help to narrow it down.
For instance a good scan tool could be connected and run a gauge sweep test. You do that and the fuel gauge goes from empty to half tank and stays there, you likely have a bad stepper motor in the gauge.
At least there is one good thing, the pump in that car is easy to get to, You remove the back seat and it has an access cover, then it's just clean away dust/dirt, remove the cover, clean around the pump. Disconnect the pump wiring, start the engine and wait for it to run out of fuel. Then remove the pumps lock ring, disconnect the fuel lines and vacuum lines. remove the pump and level sender. Reverse the process to install the new pump. Test it, then re-seal the access plate. Reinstall the seat.
Dec 31, 2016 at 10:43 PM
