Fuel gauge sometimes not working properly
1999 CHEVROLET S-10
80,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
UNKPHL
Most of the time the tank registers full tank, every now and then it will register empty. Before replacing the fuel pump I was wondering if there might be a bad ground causing the issue. Any ideas on what to look for
Oct 5, 2019 at 7:20 PM
Welcome to 2CarPros.
Anything is possible, but most times it is the rheostat on the float or a bad connect at the pump. The pump and level sensor are grounded at the same point. You can just replace the fuel level sensor. See picture 1. I highlighted the part I'm referring to. Picture 2 shows ground location.
If you need directions for tank removal, pump replacement or anything, let me know.
Oct 5, 2019 at 10:04 PM
UNKPHL
Thank you. I couldn't find any information and wanted to make sure it had a good ground before pulling the tank.
Oct 5, 2019 at 10:41 PM
Welcome back:
You're welcome. Let me know if you need anything.
Oct 6, 2019 at 7:47 PM
UNKPHL
It was the sender. thanks for the help.
Nov 2, 2019 at 5:22 PM
Welcome back:
Glad to hear you got it fixed. Were you able just to get the sender or did you have to purchase the entire assembly?
Nov 2, 2019 at 11:42 PM
