Awesome. That was going to be the next step so you were on it. I was thinking someone may have altered the vehicle so it was a matter of inspecting the housing. I didn't expect that though.
One thing I will caution you with is if you have stuff in the filter housing then that stuff has most likely gone through the filter into the injectors and back to the tank. The nice thing is, you have a 5.9L which does not have all the emissions stuff on it that the new trucks do. However, if the injectors are damaged then they will over-fuel and can cause engine damage.
I would clean all that out and then run the truck for a few hours (doesn't have to be at one time) and then change the filter again and inspect the housing. With this fuel return system it will filter the entire tank of fuel in about a couple hours of run time. That means it pumps all the fuel to the rail and that which is not used is returned to the tank. So it all passes through the filter and if you have stuff in the filter now, then you have it in the tank. I would just want to check and make sure the new filter does not get breached due to all this stuff overwhelming it and you drive the next 15,000 miles before the next filter with a breached filter.
A breached filter is when it becomes clogged and the high pressure pump just pulls the fuel and debris through the filter. This debris passing through the injectors is what damages them and causing them to over fuel.
The last thing I would do is get a bottle of the CRC diesel injector cleaner and run it through. Then change the filter after a few hours of run time and then change it again after a couple tanks of fuel. If the last one is clean then you should be good to go.
Thanks
Aug 29, 2020 at 6:58 PM
