Relieve fuel system pressure. Refer to Fuel Pressure Relief Procedure.
Raise the vehicle. Refer to Lifting and Jacking the Vehicle.
Disconnect the quick-connect fitting at the inlet of the fuel filter. Refer to Quick Connect Fitting(s) Service (Plastic Collar).
Disconnect the threaded fitting at the outlet of the fuel filter.
Drain any remaining fuel into an approved gasoline container.
You will need a 13/16 open end wrench, a 5/8 line wrench and a good pair of pliers.
Jun 11, 2019 at 2:08 PM
(Merged)
