Where is the Fuel Filter located?
2001 DODGE STRATUS
273,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
CATATTACKU
We cannot locate the fuel filter for this vehicle. Car won't start and when we took the line off the fuel rail it barely spits out any gas.
Sep 22, 2024 at 11:57 AM
The fuel filter is located on the top of the fuel tank and attached to the fuel pump module. The filter and fuel pressure regulator are a single unit. The filter is integral to the regulator.
If you look below, I attached the directions for replacing it. However, to access it, the fuel tank needs to be removed. If you do remove the tank, I would also recommend replacing the pump itself.
See pics below.
Sep 22, 2024 at 8:52 PM
