Starting issues after replacing the fuel filter
2009 VOLVO S40
160,000 MILES • 1.6L • 5 CYL • TURBO • 2WD • MANUAL
EOGHAN MAGUIRE
I changed the fuel filter on my car listed above diesel. it started and then shut off after 10 seconds. It then would turn over but wouldn’t start. Now it has stopped turning over and only a clicking noise remains. What should I do?
Oct 23, 2020 at 11:02 AM
I'm not sure why, but this engine isn't listed in my manuals. If you are not in the US, that could be why.
However, if you are getting only a clicking sound, then chances are the battery is dead from trying to start it so many times. Take a look through this link and let me know if it mirrors what you are experiencing.
https://www.2carpros.com/articles/symptoms-of-a-bad-car-battery
If it does, then the battery needs recharging. Here is a link to help.
https://www.2carpros.com/articles/how-to-charge-your-car-battery
_________________________
Because I have no technical info on the no-start condition, what I suggest is to see if the injectors need bleeding. Basically, air can create a pocket and prevent fuel from entering the engine.
Oct 23, 2020 at 11:26 AM
