Hello, I'm Danny.
Here is the information you requested. The fuel filter is built into the in-tank fuel pump and fuel sending unit assembly which is mounted inside the fuel tank. The fuel filter is only replaceable if the fuel pump-sending unit has failed or needing replacement. If you have any further questions on this issue let us know and we'll go from there. Hope this helps and thanks for using 2CarPros.
Jul 1, 2021 at 12:55 AM
