You are correct. It is in the tank as part of the fuel pump assembly. However, you do not have to service this filter. It is only to be replaced if there is an issue that you have to remove the pump. When you remove the pump you put a new filter on it. Otherwise, the filter just stays in place.
Let me know if you have questions. Thanks
Jul 3, 2020 at 5:53 PM
