The fuel filter on this vehicle is mounted on the fuel pump in the fuel tank. If you look at the pics below, I included the directions for the removal and replacement of the pump and filter.
To access the fuel pump, you first need to remove the rear seat. Under the seat is a service port. See pics 1 and 2. Remove the cover to access the pump.
Remember, the fuel is under pressure, so use caution when disconnecting the fuel lines. The remaining pics are the filter replacement procedures.
See pics below.
Mar 18, 2022 at 9:37 PM
