Fuel Filter?
2007 GMC ENVOY
112,715 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
STEVE620
  • 70 POSTS
I can't seem to find a gas filter online, does the vehicle listed above have one?
Nov 19, 2022 at 5:25 PM
STEVE W.
  • 15,113 POSTS
It has a filter inside the tank as part of the fuel pump assembly. Unless you are seeing signs of poor fuel flow or contamination in the fuel it's not a real service item. If you wanted to change it you would need to run as much fuel out of the tank as possible, remove the lines and connections and drop the tank out, then swap the pump module.
Nov 19, 2022 at 6:04 PM
STEVE620
  • 70 POSTS
thank you.
Nov 20, 2022 at 3:24 AM
