I need to know how to change the fuel filler neck step by step i believe this is what's preventing me from refueling, causing the pump to shut off every few seconds. This seems to be a common thing with this model. When i bought it i went to put gas in it and noticed the opening you out the gas pump in was loose so i tightened up the mounting screws and changed the hose at the bottom of the neck that connects to the fuel tank due to it deteriorating and the gas cap and cel lights on the dash were on so i changed the cap. I ran a code scan and it said a small emissions leak after researching the issue it says to change the neck if this don't work try blowing air through it idk how or what they mean by it and then to check the evap canister and lines again not sure of how to do this ether so if you can help guide me through each of these steps to see if the issue can be fixed would be great.
Jan 5, 2025 at 12:09 PM
