Poor fuel economy
2019 BMW 118I
660 MILES • 1.5L • TURBO • 2WD • AUTOMATIC
R4HEM
Hi
i have the car listed above Shadow Edition 2019. it has only done 660 miles and it is giving me 20 mpg i don't drive it fast and i drive it in eco mode. please advise what the issue is? thank you!
Apr 30, 2019 at 6:53 AM
Hi R4HEM,
There are many things that cause poor fuel mileage but on a vehicle this new most of those will not apply. This vehicle looks like it is rated in the high 30 MPGs. Is that correct?
If so and you are only getting 20 I would suggest planning on having the vehicle checked by the dealer because you are obviously still under warranty.
Last thing is if your vehicle is equipped with ECO pro? If so, this mile per gallon in the high thieves is most definitely achieved using this setting. Also, if you are currently using sport mode or sport + (if yours is equipped) then this would explain why yours is so much lower. Sport mode gives very aggressive shift points and will seriously cut your fuel mileage even if you are not driving fast. Hard acceleration from stop lights or aggressive driving without speeding will effect it
Check out this video and if none of this applies, I think the best bet is to have the dealer look at it. Thanks.
https://youtu.be/tP_HVosFPa4
Apr 30, 2019 at 6:07 PM
