Running too lean and backfiring while driving
2007 GMC YUKON
175,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
BRIANNAAALETA
  • 8 POSTS
My SUV has had a lot of problems with the fuel delivery system. The system is running too lean, its misfiring, backfiring in the manifold, and the exhaust when you're driving. It sounds like tennis balls are popping everywhere. You give it too much gas, it cuts off. it gets no power and stalls when I start to slow down it cuts off. I changed my fuel pump and it's doing the same thing.
Jun 26, 2022 at 12:46 PM
It sounds like it could be a bad MAF sensor, if so, it will tell the computer the volume of air is way less than what is going into the engine, therefore the mixture will be lean. We should run the codes to see what comes up. here is a guide to help:
Also, the engine can be having a mechanical issue, but I can tell for sure if you please upload a short video here in your response. I would remove the spark plugs to check their condition and do a compression test to make sure the engine is okay.
Jun 27, 2022 at 9:45 AM
BRIANNAAALETA
  • 8 POSTS
It's throwing these codes now, but I clear it every time and when I read the codes again it's always popping up something different.
P0171
P0174
C342D
P0055
Are the codes it's throwing now but these are some of the codes that have been popping up.
P0326
P0335 which is the initial code it was throwing I've changed the crankshaft, but it wasn't a brand new one.
P0068
P0102
C3064
P0068
C2174
C0361
C2520
There are numerous more that it has read just today.
Jun 27, 2022 at 6:35 PM
How does the engine wiring look, in good shape? With this many problems and codes, it sounds like the PCM is bad. To be sure let's do a CAN scan which is the future of automotive repair you can get a CAN scanner from Amazon for about $30.00. here is a video to show you how and a link to a scanner from Amazon:
https://youtu.be/u-4syLc-ifQ
and
https://amzn.to/3OpAotj for the scanner
Also try to clear the codes, then shut the key off, then turn the key on without starting or cranking the engine over and then run the codes again to see what comes up. Check to make sure the engine and body have a good ground as well. Here is how to replace the PCM in the diagrams below.
Jun 28, 2022 at 11:41 AM
