Fuel delivery issues?
1979 CHEVROLET EL CAMINO
5,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
MOTOPSYCHO
  • 7 POSTS
I have done all I can think of. The fuel pump works, I replaced the fuel pressure regulator, had the carburetor rebuilt, replaced fuel lines as needed and had the vehicle timed. I'm getting fuel past the fuel regulator and there is fuel in the fuel bowls on the carb, but it still won't start. The carburetor is a Barry Grant 650 demon quad. For whatever reason, the carb doesn't seem to be taking in the fuel. The tank is full, and I did remove the hose from the carb inlet and put it in a gas cannot be too sure fuel is making through. I drained at least a gallon, but when I replaced the hose, nada. Please advise me what else might be the problem. Thanks
Aug 11, 2023 at 6:45 PM
Will it run on starter fluid? Also, I have seen the fuel line back by the tank crank and such air in without leaking fuel. When you take the fuel line off of the carburetor and crank the engine over does a good steam of fuel gets pumped out? If so, you may have a float that is stuck or the cap that covers the fuel inlet to the carb has its plastic cover over it still.
Aug 12, 2023 at 2:49 PM
MOTOPSYCHO
  • 7 POSTS
It doesn't run on starter fluid. There is a good stream of fuel coming out of the hose. I rebuilt the carburetor and change all of the fuel lines.
Aug 14, 2023 at 11:14 AM
MOTOPSYCHO
  • 7 POSTS
It doesn't run on starter fluid. There is a a good stream of fuel coming out of the hose. I rebuilt the carb and change all of the fuel line
Aug 14, 2023 at 11:16 AM
MOTOPSYCHO
  • 7 POSTS
How do I check the floats?
Aug 14, 2023 at 11:17 AM
If it doesn't run on starting fluid the fuel is not the problem, do you have spark?
Aug 15, 2023 at 8:26 AM
MOTOPSYCHO
  • 7 POSTS
Yes, I do. I checked the number 1 plug. The plugs and plug wires are all new. I appreciate your responding to me and hope you'll be able to help me get my Elco back in the road.
Aug 15, 2023 at 11:03 AM
How does it sound when cranking over? Can you upload a short video of the engine cranking, in the meantime can you do a compression test?
This guide may help as well:
https://www.2carpros.com/articles/car-not-running-advanced
Please go over these guides and get back to us.
Aug 16, 2023 at 10:56 AM
