fuel cutoff relay
1988 HONDA ACCORD
317,600 MILES • 2.0L • 4 CYL • FWD • MANUAL
BILLTHIB
I had to replace the relay, so the car starts and runs well. I have been told that the relay malfunctions due to getting hot. If this is true, can it be re-used after it cools off?
Aug 20, 2017 at 8:42 PM
The relay gets hot because the fuel pump is going out and it is pulling too much amperage. You should replace the pump and the relay.
Aug 21, 2017 at 5:52 PM
BILLTHIB
Thanks for your response. I did have the fuel pump replaced a few years ago. Any idea how long it may take for the relay to overheat? Also, how often would this problem occur?
Aug 23, 2017 at 7:14 PM
The more resistance the more rapidly it will heat up.
Aug 24, 2017 at 10:21 AM
