Took my vehicle in as it had glow lamp fault light illuminated and then started to run a bit lumpy. The garage eventually cited the EGR valve which they replaced under warranty, carried out a routine minor service and then returned the car to me. However, the car was still running rough and same fault light came straight back on. Now the garage are saying it is fuel contamination- petrol in diesel tank- that has damaged the fuel injectors. Is it right that they failed to spot the fuel contamination in the first place? Even when they carried out lots of diagnostics and replaced the EGR valve and serviced the car?
Oct 7, 2018 at 12:00 PM
