There are two ways to clear the Malfunction Indicator Lamp[MIL] or "check engine" light. The first, and preferred method, is to clear the MIL with a scan tool, the same one used to pull the code from the Data Link Connector[DLC]. The second, and less approved method because it wipes out the Keep Alive Memory[KAM] and your vehicle will have to relearn some things[through normal driving], is to disconnect your vehicle's negative battery clamp from the negative battery terminal for at least 5 minutes, then connect it back to the terminal. Both of these techniques work, but, again, the former is preferred to the latter. I hope this helps.
Thanks,
Alex
2CarPros
Nov 13, 2019 at 1:40 AM
