In the 1983 Cadillac Cimarron, the fuel pump relay is typically located in the engine compartment, specifically in the relay/fuse center. However, please note that the exact location of the relay can vary depending on the specific model and trim level of your vehicle. To locate the fuel pump relay, follow these general steps:
Open the hood of your Cadillac Cimarron.
Locate the relay/fuse center. It is usually a black box or panel that contains multiple relays and fuses.
The fuel pump relay should be labeled for identification. Look for labels such as "F/Pump" or "Fuel Pump."
Once you identify the fuel pump relay, you can remove and replace it if necessary.
May 19, 2023 at 11:27 AM
