That is going to make it harder, depending on what is broken you will probably need to replace the ignition switch housing and the lock cylinder. Possibly the transponder antenna as well. Could you take pictures of the area you "smashed" to give us an idea of which parts are damaged. Do you have a bi-directional scan tool in case you have to replace the transponder module? It has to be programmed into the PCM for it to work.
Mar 14, 2026 at 10:01 AM
