WELL, IDLES IS A GOOD THING!
I BELIEVE I'D DROP THE TANK AND EMPTY/ CLEAN IT.
THREE YEARS IS A LONG TIME FOR A CARB TO SIT WITH STALE/ NOW VARNISH FUEL INSIDE IT. REBUILD OR REPLACEMENT IS WHAT SHOULD HAPPEN TO MR. CARB
MOST LIKELY THESE ARE "GIVENS" THAT SHOULD BE ADDRESSED FIRST
ONCE THESE ARE NO LONGER BAD FACTORS , EVERYTHING MIGHT GO JUST FINE!
IF NOT, WE CAN CONTINUE WORKING ON OTHER PROBLEMS
YOU NEED TO VERIFY WHETHER YOU HAVE A 232 OR A 199 INLINE SIX CYLINDER.
JUST FOR GIGGLES, I LOOKED UP A CARB FOR THE 232
IT'S AN ORDER ITEM ONLY
-IT HAS A $36 CORE, WHICH YOU WILL GET BACK IF YOU TURN THE OLD ONE IN TO THE STORE
http://shop.advanceautoparts.com/p/autoline-remanufactured-carburetor-c7000/20122919-P?searchTerm=carburetors
IF YOU HAVE THE 199, LOOK UP IT'S CARB ON THAT SITE
LET'S MAKE THIS EVEN BETTER- LETS SAVE ANOTHER $40 ON THIS ORDER!
"TRT41" PROMO CODE WILL KNOCK OF $40, SO THE ORDER WILL BE $199.99 + $36 CORE -MINUS $40 PROMO. THE ORDER WILL BE $195.99. WHEN YOU TURN THE CORE IN, YOU WILL HAVE ACTUALLY SPENT ONLY $159.99! SHIPPING IS FREE!
EVEN THOUGH THIS IS A ONLINE ORDER ONLY, OTHER STUFF YOU NEED CAN BE OBTAINED IN A SIMILAR MANNER, BUT PICKED UP AT THE STORE IN 30 MINUTES! SEE HOW THIS WORKS IN THIS LINK
https://www.2carpros.com/questions/2001-dodge-neon-milage-just-want-put-fliuds-their-locations
KEEP RESPONDING, WE WILL KEEP GOING!
THE MEDIC
Feb 12, 2016 at 5:29 PM
