applying the brakes and the ABS was "pulsing", there was a loud grinding noise from the front passenger side wheel? Then it locked
2007 FORD F-150
104,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
RICKMUR
As I was driving down an icy, dirt road, I was applying the brakes and the ABS was "pulsing", there was a loud grinding noise from the front passenger side wheel. Suddenly, the front wheels appeared to lock up and the rear end of the truck spun around. I had to take the truck out of gear and put it back in drive to continue. I was able to get the truck home but the grinding from the front passenger side wheel was very loud and as I came to each stop, the wheel locked up and I was unable to proceed until I took it out of gear and then put it back in drive. If I were on a downhill slope at a stop sign, I had to put the transmission in reverse, back up slightly, then back to drive before I could move forward. Out of curiosity, I went to an empty parking lot, put the truck in reverse, backed up at a fairly good speed and distance, applied the brakes and there was no grinding or lock up? Your thoughts and remedy on this situation would be greatly appreciated. Thank you
Dec 14, 2014 at 5:47 AM
Good evening.
First, there is an ABS code stored in the system. I would like that code if possible. A parts store can read it for you for free then we can narrow the area of failure.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
As far as the grinding, it sounds like the caliper may have locked up dragging the brakes when you try to stop. I would remove the wheel and inspect the right front and make sure the wheel spins when you have it off the ground.
https://www.2carpros.com/articles/brake-caliper-replacement
Beyond that, The ABS action is normal except for continued lock up after the brakes are released.
Apr 1, 2020 at 6:07 PM
