front wheel bearing hub assembly torque values
1995 BUICK CENTURY
90,000 MILES
WPBRINK
Replacing front wheel bearing and I don't know the torque values on the 3 bolts that are associated with the wheel bearing housing assembly. The only info I have is for the axle but which says 138 ft. Lbs.
Oct 13, 2013 at 1:10 AM
HMAC300
  • 48,601 POSTS
63 ft lbs for the three bolts here is a guide that will walk you through how to do the job.
https://www.2carpros.com/articles/bearing-hub-replacement
Oct 13, 2013 at 5:59 AM
